Theoutdoorsman
- Mar 6, 2003
- 676
Should a slight difference in horsepower be expected with a .030 over piston change on all four holes. Just curious as to weather or not I might need to consider a change in prop size after this rebuild is complete. My current prop was turning about 5600-5800 rpm's, prior to pulling the powerhead, and all depending on my load. I would assume not, but the thought did cross my mind as I'm not sure how much, if any, this would affect the hp of the powerhead. Also, with the change of the piston size, what are some things to consider in terms of preventative maintanance and care? Any additional steps to consider? Obviously, the occassional decarbing of this rebuild using SeaFoam is of the utmost importance. Can this be used as a fuel addative along with Stabil and run through a water seperator without any problems? Sorry for all the questions.............Thanks in advance..................ALAN
1979 Evinrude 140hp
1979 Evinrude 140hp
