Quick Thermostat Gasket Question - DON? Bond-O?
Don S
Re: Quick Thermostat Gasket Question - DON? Bond-O?
One gasket, a thin coat of Perfect Seal (or equivalant) on each side of the gasket, and you should be good to go.
JustJason
Don.... any idea if 847 is equivalant to perfect seal? Just curious... figure you would know.
Don S
Have no idea Jason, never seen it, used it, or heard of it till now.
JustJason
It seems to be just like OMC type M... if you remember that stuff.
JustJason
sorry to hijack.... maybe i'll try and put together a lube and glue sticky.
Shaun78
The manual says I think...Not to use perfect seal on the thermostat housing gasket. I messes with the 2 metal tabs or something causing false gauge readings or something like that anyways
valkyr
yeah, i can't use sealant on the housing gasket (lower gasket) because of the rivet things in the gasket...cannot remember the technical term. Messes with the temp sender if you do.
valkyr
Errrrrgggg
Well got the thermostat on, replaced the hoses all good right?
Wrong. Broke a piece of the temperature sensor unit that screws into the thermostat housing.
*sigh*
JustJason
Thats ok... you don't need that temperature sensor thing anyways....
here's what i do.... I duct tape a teapot on each riser.... and I listen for a whistle.
hal2814
Errrrrgggg
*sigh*
I broke one of the wires for that sensor but was able to solder a new flag onto it and get it back into working order. The whole sensor unit is a bit fragile for all the thick metal that it's attached to.
