fngboater
- Jun 9, 2011
- 181
i am in the process of adjusting my throttle/shifter cables on the motor and i have the shift assist,spring loaded thingamajig. manual #14 states:
so i need to know if the quicksilver 3000 classic shifter (the one i have) is the same as the commander 3000 shifter.
i put the shift assist on but i had to compress it maybe a 1/4 inch to align with the stud. if i do need to adjust the shift cable, which one am i adjusting...the one to the remote control or the one to the unit?
lastly it seems as though there is a lot of travel from full forward to reverse and vice versa...is that normal?
For Commander 3000 Controls,
if shift assist assembly attaching points do not align, verifycontroller is in the neutral position. Remove the shift cable and reposition the adjustmentbarrel as required to allow the shift assembly to be installed with no effort.
For ALL other controls
if shift assist assembly attaching points do not align, push in or
pull out on end of shift assist assembly to install. Do not attempt to readjust shift cable.For ALL other controls
