Quotes
yorab
Ensign
When I use the reply with quote, the entire post is quoted. I then have to delete all sentences except those that I want to quote. Is there a faster way to only quote a portion of a post without deleting a bunch of text?
Also, how do you quote multiple parts of a post that aren't connected? For instance, if somebody asks three questions at different parts of their post, how can I quote their questions followed by my answer for each? Thanks.
eavega
Re: Quotes
Quotes work with the tags that surround them .
USERNAME.... said:
the quote[./QUOTE] would be
USERNAME.... said:
the quote
if you remove the period before the first [ in the first tag and the period before the / in the second tag
To quote multiple parts of a post, just duplicate both sets of tags, the first one begins a quote and the second one closes the quote
is
Quotes
Rgds
Re: Quotes
Or,... Click on reply...
Click on the quote button at the top of the dialog box, it'll insert the quote tags wherever the cursor is...
Then C&P the text you want from the post into the box, between the quote tags...
QC
Re: Quotes
When I use the reply with quote, the entire post is quoted. I then have to delete all sentences except those that I want to quote. Is there a faster way to only quote a portion of a post without deleting a bunch of text?.
Deleting chunks is faster for me than other methods.
Like this?
You can mulitple quote by C and P the whole quote box, and then deleting what you don't want for each separate quote. Pretty fast for me . . . :)
veritas honus
Re: Quotes
Thank you for divulging this secret information which until now, I had no clue;)...
I had finally figured out how to use multi-quote. Don't know if I ever would have figured this out on my own, though. Again, thanks:D.
veritas honus
Re: Quotes
Uhhh . . . can you share that secret information? :redface:
You serious?... I was referring to the "secret" information you've so generously divulged; which, incidentally, was the inspiration for my reply:p.
ezmobee
Re: Quotes
I thank you for taking the time to learn this instead of quoting the whole darn 12 paragraph post to respond to one sentence like a lot of others do!
Re: Quotes
Quotes work with the tags that surround them .]
USERNAME.... said:
the quote
would be
is
Quotes
Rgds
Like this?
see if I got this
I can do it this way
Thanks guys!!
He could......but then he would have to kill you:D
Ayuh,... Ya mean like This,..??..??
LippCJ7
Re: Quotes
WAIT WAIT WAIT! Bond-o put quotes inside of quotes can I cut/paste that too? Except without the Ayuh of course, I think that is copyrighted....
