Expidia
- Aug 26, 2006
- 2,368
Re: Raised outboard up two holes . . . and WOW!
Update: I was getting a little twist to the outboard at high speeds.
So I found an installation doucument that came with the Merc. This manual notes to install with the anti-ventilation plate inline or 1 inch below the bottom of the boat.
I personally found, at least with the design on my Lund's hull, that "so far" it has improved handling when mounted within 1 inch "above" the boat's bottom. So two holes might be a tad high now.
This manual also notes that the little vertical trim tab that hangs off the end of the anti-ventilation plate will have little effect in reducing steering torque if the outboard is mounted above 2 inches from the boats bottom.
I'm only at 1 inch above now so the 20 degree twist to the outboard was probably caused by the motor now being mounted above the bottom and it was probably worse when the motor was trimmed out (up) too far.
Yesterday, I found that at wot when I let go of the wheel the boat would turn to the right. I didn't notice this before because I don't run wot much. So I pulled over to a dock and adjusted that tab a 1/4 of an inch in the direction the motor was turning to compensate for the higher speed wheel pull. It's worked out fine so far, no more pull to right.
The next time I have a friend over to help with holding the bolt heads (oops, had to re-phrase cause almost said he could help me hold my nuts
I might try and go down 1 hole of the two I went up. I do notice now if I have the motor trimmed up too high before I hit it from a dead start the prop does not grab as well until I start trimming it down.
I'm also sometimes catching some prop air if I'm riding along at higher speeds and hit choppy water. Trimming down a little helps the prop grab in. Still, my guess is the sweet spot for my rig (with no spray and good handling) is going to be probably only up 1 hole, not two where it is now.
Problem is if I go down one hole again and the spray is back, I'll have to do it all over again
for a 3rd time and go back up to the two hole position. At least I now know to use my electric wrench this time around on those long bolt threads.
** I wish this setup had a better height adjustment system. Is there an accessory that I can add that will allow me to adjust the height without having to unbolt each time?
Tip: the book also said not to put any sealer on the bolt's threads when re-installing (only use sealer on the shafts). Glad I used the 4200 not the 5200 sealer or I'd probably never get them back out again!
