Re: Ranger livewell problems
Brian, I thought from some of the literature that they had kits also, but that is not the case.  They only make kits for boat manufacturers.  Unfortunately you will have to order items individually.    Its a bit confusing at first, but take your time and the system items will start to make sense.   Also, they do not sell pumps....just use what you have, or order whatever you need.  They recommend 750 gph.  I have a 500 gph pump that I'm going to try to use for the front LW, and ordered a 750 gph pump elsewhere that I plan to install for the rear LW.
Use flow-rites interactive builder if you haven't already, and you can click on each individual piece to see exactly what you need.   Be sure to take note of the QL - quick lock items they incorporate.   The 'Quick lock' items are designed to fore-go typical hose clamps.  You install the ql clamps to the hoses you wish to use that on, and then they just snap onto any QL valve or aerator.   If you don't want QL's then just order the barbed version valves etc and use a normal hose clamp.   I went ahead and got the QL valves and aerators just to make it all easier.   All the quick lock items part numbers end in -QL.
If you already have the pumps and hose, probably all you need for system 3 is, 2-V3R valves, 2 RK3 actuators, and 2 cables (measure the length of your current cables before purchase).
Rangers default aerator idea was just a PVC cap screwed onto the pipe with a notch cut into them that sprays water in the well.  I  purchased the power stream aerator for the front LW (for delicate bait), and a power nozzle for the rear LW.  I may switch the rear one to a power stream style also once I see it all working.
You can use their contact page and call them if you have any other questions.  Roger is the guys name that I spoke with.  Very nice fellow, and very helpful.
I should be getting my parts this coming weekend.  I will definitely take pics during the install and show them here, since the Ranger livewell issue on older boats seems to be difficult to find info on.   Not much info on-line anywhere that I could find, so I would be happy to share.
I can't wait to get this thing working....tired of water (and bait) flooding the bilge....lol  :^
