Ratherb's 74' 21 Ft Starcraft Islander
Ratherbboatin
120 to 92 lowest, but it was a new tester that I used due to the deeper plug holes. My other tester is better. With those numbers it should not run.
Watermann
I would hold off on the tear down until you can run some water to the motor, get it to operating temps, do a decarb on the motor and then recheck the compression.
Ratherbboatin
Whats a decarb? Maybe a stupid question
I still need to go through the fluids. PO told me oil was changed about 6 months before I got it. Oil is dirty now, but was believable so I need to change it and change the closed cooling fluid.
I also have the outdrive pulled parts and going through that. Will need a seal kit and all new top bearings.
y4mRe-4dKl2KDHT3pX30xdEyKXxUf8LlQezLyNV638ZslBi0r6vCFV61Nd8Adi6e--x8AYzWu_zoinOVW-GfCQHu7Lsc-epTdj-oSR3WqflPTr1_86In4V_i15qKYn80S09F9nPaO35EXthM1gw8gsMszExj2ng0uvd7P_b9FqlbWEBzjOzhwrdBP3mhLzjXNidlPDOYvTZcSxEh1bF9o2w_Q
y4mReBE2hPcmr9xIzu3kwDY72Pl_lL1nTWRu8BgFw3fQTasmZwAfq9HgHA8RE9smymja9SmHW7W-uaQE4yTzjQ4DY5qipBrqBsldOg-ltbmUxKSaBSAwfbV2YTB7MnfiPp-GvKi2iPI5Zf1z34XmAKx2SRbyVJ-lZOmFaXhlrRmSSEaIUd2r1KB_TTIGPZk_mPHJVq0YoZm6M8fHZ2gyKylrg
y4mylcmDVreopFkTRKufF6kCwyjFjdSyW2bQVd3B9sRNmTZfMiEtOvFv7HVn8dnQzlCQob3L17LO6OWnngie51Mc3jeiHB3iNWG9XCmDm9wDcB8fcElrEEhL-EGl2d_a0xIKwLpy9NU_BRLjHyRla7t-03XSJCQi7CBudh3iW9VMUi371yuRHDnhHt-fob4KjR3MQfIFFegwPR-8imZMPdZKA
Ratherbboatin
Anyone know how that top bearing comes off? I have watched many videos of leg rebuilds, but no one seems to take them off. I will need to replace mine. Looks to be pushed on?
cj8mule
Can't help you with that outdrive bearing, but the manual should tell you. When I had my 165hp mercruiser, I downloaded the full manual (which included the outdrive rebuild section).
X2 to what Waterman said about getting some water to that motor and running it for a while. Those compression numbers will probably get more consistence after running a gallon of fuel through it.
--dave
oldrem
Seafoam works wonders, been using it several years. Just had to decarb my big snow blower with it Sunday just in time for a snow dump we got on Tuesday
Ratherbboatin
WM - ok, I have watched videos of the seafoam. Never heard the decarb term used. LOL don't forget I am Canadian.
oldrem - Keep your snow, I don't want it
Ratherbboatin
OK, so that last week, I have come across a couple boats I just could not say no to.
Fist I bought a 16' Prowler bowrider with a 3 ltr in it for a crazy price, sorry no pics on that one right now. Needs the starter and ignition changed before I can get it running.
Today I went and picked up a 22' Starcraft Chieftain. The hull floor and transom are in great condition. Does not have a motor or leg, but is a merc cutout so should be easy to find.
Waterman, I know you will like this photo!!
66Holiday924
Nice looking Chief! That canvas looks good in the pictures and with the floor and transom in good shape, you probably got a good deal.
Ratherbboatin
Replaced the plugs and ran the 165 for about 45 mins today. I finally got the fitting to connect it to the water hose. Easy to start after I got the fuel going, ran like it was new.
I have the pre-alpha drive half pulled apart to rebuild. Does anyone have a good video or instructions on how to take the gimbal ring off and breakdown the transom housing?
