Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
Current state of the project. I have only spent a few hours working on it, too many other things to do.
-Repaired aluminum above the top of the V on the lower window
-Drilled out an re-riveted the aluminum where the lower window posts mount to fix the large spacing on the window
I like your new shop too, and the new admiral approved boat. Sometimes people loose motivation on their projects when they add a new boat to the fleet. Good to see you're still working on the Islander.
Upper Windshield now on! I am still trying to find some replacement rubber U channel for the lower window. It shrunk over 2 inches and is now way too short.
Man, I love the lines of these vintage Islanders. Looks like something Seal Team Six would be using. Great job on the fix and restore. I missed the beginning so I'll catch up in the next couple of days.
Lower Hull
The stripper works very well. I should pull the boat out and use the pressure washer to strip it, but I am applying and using a scrub brush to take off the old paint seems to work well.
The trailer is a split quad bunk version, not the best for this type of boat. It does fit better than all the other trailers I tried. I may change the quad bunks to 2 long 2 x 6 polymer covered down the road. It all comes down to cost, even switching the bunks over and using the existing mounts will be around $160 cdn. Our money is not worth anything right now.
I actually own a trailer business here in B.C. Canada www.jseequipment.com I am a dealer for Karavan and EZ Loader. Customers trade in used trailers when they buy new ones so who knows the trailer may get swapped again.
