raw water pump bearing
galaxy 215
Hello everyone. As I progress in my boat repair I now have the engine in pieces(rusty cylinder walls) I have found everything I need to do to it and have 99% of the parts. I just need to know where to find a comprehensive rebuild kit for the raw water pump. I believe it's a Johnson f5 pump? Mounted to the front of the crankshaft pulley and has a splined impeller. Thanks for any replies
Re: raw water pump bearing
Ayuh,.... Welcome Aboard,.... How 'bout some hints on what We're workin' on,..??
What motor,..??
What drive,..??
What vintage,..??
galaxy 215
Engine is a 4.3 chevy,outdrive is Volvo penta dp-c,boat is a 1992 galaxy cuddy. Impeller confirms it's a Johnson pump.
dypcdiver
There are several posts on this forum that detail just what you want, please use the search at the top of this page.
jerryjerry05
If you can't find it here.
Try Cobe Marine in Pasadena,Md.
Good Volvo parts and have all the pump and cooling parts you'll need.
galaxy 215
Things are going very well . Bellhousing all redone with new bearing/seals,raw water pump rebuilt with Volvo parts,engine almost done(waiting for head gaskets), outdrive just needs reassembly, Going to wait till spring for outdrive reinstall and engine run but I'm very happy with the cost of the parts .I've used-both marine and non marine. I have about 500 into the entire driveline. Rings,bearings,u joints,seals, gear oil, head resurface,gaskets. Should be a fun summer. Just wanted to say ,thanks to everyone here for there help/comments in my driveline overhaul.
