Donald0039
- Jun 11, 2022
- 427
I see some dripping from the raw water pump after shutting down the engine. I was hoping it was the O-ring for the outer housing but the sealing area of the outer housing looked fine as did the O-ring.
So now I think it's the shaft seal. Hopefully the leaking seal has not allowed damage to the bearing.
It does not look like too much work to replace the seal. The bearing would be more work.
A new pump is $500.
Sending it out for a rebuild is $200.
Has anyone needed to replace the seal because of a drip or leak? Was the bearing still good?
A new pump is $500.
