Re; Broke spark plug
Lou C
Same thing with the Cobra, there is a nipple on the impeller housing, with a small rubber hose attached, that allows it to prime. I make sure that this is open every season before commissioning the boat. I remove the end of the hose and use a compressed air can to make sure its clear.
The right muffs make all the difference with this problem.
kash35
with an engine mounted impeller, if the water line drained of water when the boat was pulled out, unless your muffs fit really well you can have this problem. Not as common on an Alpha since the raw water impeller is right in the lower gear housing and the water doesn't have to travel far before the impeller can pull it in. On a Volvo, or Bravo system the water has to travel up 1.5' and approx 3-4' forward to reach the impeller. I used to use the Tempo style muffs dual inlet and the last pair of them I used (right after my top end overhaul) it seemed that the rubber was stiffer and I could not get my Cobra to prime easily as I had in the past. The Cobra is a little different from the Alpha in that the impeller is in the upper gear housing (very easy to replace) but water has to travel about 1.5' up to reach it. I switched to the Merc/Quicksilver round ones with the metal rod clamp and it was 100% better. The Merc muffs are softer rubber that conforms to the shape of the lower unit better and the clamp holds it tight. Well worth the extra $$
After starting the engine you should see water getting exhausted under the transom mount within seconds. If not then its not pulling in water and remember impellers can't move air only water.
notice how much water is exiting the transom mount in the vid.
This makes sense. I attached the hose to the engine mounted flush hose and everything seemed to be working. Ran the engine for about 15 minutes and temperature was normal. There's no blockage anywhere. I'll really find out once I take it out on the water but thanks for the help.
Lou C
Sure thing the engine mounted flush hose eliminates the issue of the muffs not fitting etc.
