Re-post of Boomyal's Brined Turkey Recipe!
sangerwaker
Flathead,
Is this just a store bought bird that is frozen? If so, yes, no issue. That's what we use every time we make this brine. Thaw the turkey, brine per recipe, and enjoy. Absolutely delicious smoked with some apple, hickory, and/or pecan. Cook to about 165 to 170 max. The juices just run out when you slice it. Soooo good.
FLATHEAD
Flathead,
Good info, thanks for that.
aspeck
Yes, I like the apple and hickory smoke … 2/3 apple, 1/3 hickory. I pull the bird at about 150-155 …
FLATHEAD
And either here or in the cooking thread can you please post cook details.
Not much to post. Gave it a 12 hour bath in Boomyalls brine. Rinsed it, pat it dry put a little black pepper on it. Smoked at 250/300*. Used a combo of apple wood and a little red oak. No spritzing, no basting just let it go. Not even sure how heavy that bird was, about 10 pounds? Was done in a little over three hours. Was super moist and tasty.
redneck joe
So, all smoke like a smoker or like me with an egg? And what temp internal did you pull off to rest, and lastly did you air dry the bird any?
aspeck
I have never dried the bird … just taken it from the brine to the smoker. I cook at a lower temp for a little longer … a wet smoke … and I use maple syrup instead of the brown sugar …
FLATHEAD
I use an offset smoker and use wood. Pulled it at 165 and let it sit tented with foil for about half hour.
DeepCMark58A
Time to move this back to the top, I brined a turkey for the first time last year using this recipe and it makes a big difference in flavor. I got a free 5 gallon food grade bucket with a lid from the local grocery store for free. It is the official brine bucket.
aspeck
Maybe not "Food Grade," but I put a plastic bag in a 5 gal bucket and depending on size of the bird, but things around the bird outside the bag to help fill the area and use less brine. Then tie the bag tight to help pull the brine around the top of the bird.
As for kind of turkey ... when brining a bird, get the cheapest bird you can find. The brine will work wonders. I have used all kinds of birds from wild turkey to el cheapo store brands to Butterballs. After the brine bath they all taste the same and have the same level of juiciness!
redneck joe
Did you mean brined? Answer is no I buy a butterball frozen turkey.
If it has 'X% solution of xyz added' it is brined.
AI Overview
+10
The phrase "percent solution added" on turkey meat packaging means the product has been injected with a solution, typically of water, salt, and other ingredients (like phosphates, flavorings, or antioxidants), to improve its moisture content, tenderness, and flavor. The percentage indicates how much the product's weight has increased due to this added liquid.
DeepCMark58A
AI Overview
+10
The only thing I read on the turkey bag is the weight.
sangerwaker
Joe,
Think Nike. Just Do It! Any store bought frozen bid, whether brined per your AI overview or not is fine for this recipe. It has converted many people, including me and my family. It adds great flavor and juiciness.
BTW...Butterball is injected. No matter. They turn out wonderful. Have made several and even more breasts only (my wife's preference). I even use this brine recipe for wings. Do a bunch at a time, dry rub them after brining, and vacuum seal them before freezing. Thaw 'em out, and toss on the smoker when I have a craving.
I'm not cooking the turkey this year, but will make a brined, smoked bird or breast at some point over the winter.
