I have a separate post up with questions about a floor restoration. While I have the floor off, I'm inspecting the interior structures.
Not sure what to do with this part: There are rectangular boxes full of foam (I know that 'cause a little extruded from the factory) on each side, running from the transom forward about 5 feet, right next to each gunwale, positioned in beween the fuel tank and the gunwale. The fiberglass is largely intact, and the tops are flat.
It looks like they were once secured to the gunwales with mat running about 3 inches up the inner wall of the hull. (See photo.)
There is now about 1/4 inch gap (see white arrows) between the mat and the hull. Looks like it used to be attached.
I don't think that mat has any structural effect (it's attached, or was attached, to a very flexible part of the hull, near the top to the gunwale). I think it's only purpose is to trap any water coming down the inside of the hull and redirect it into the bilge or the forward compartment (where it will then drain back to the bilge).
I'm just wondering how and whether to re-attach it.
Just lay another piece of mat on top (pretty sure that will pull right off like the old one)? Insert some treated plywood or "peanut butter" resin and chopped glass to fill the gap, then mat over? Leave it alone, it's been that way a long time and waddaya want it's an old boat?
