I have a 1985 Johnson 150 Gt. One owner. Problem is it stalls at 2500 rpms. Will not plane out. It starts real easy and idles great. With muffs, it will rev up fine, but under a load it stalls. I soaked and cleaned and rebuilt the carbs, new power packs, new vro pump, new stator, Check compression, all cylinders within 2 lbs, all about 80lbs, Pulled the heads and check the pistons, pistons seem to still have good sharp edges on the domes, and the cylinder walls are good. Replaced with new head gaskets, new intake gasket and carb gasket, new gas lines, new gas filter, checked gas tank vents, new plugs and wires and still will not plane. Sometimes the engine will shut off when put in gear. does not have enough power to load on the trailer. Had to use the crank to load boat on trailer. I have been all summer on this problem. Does anyone have any ideals on what the problem could be or what to look for. Help me, Please
