Rear axle again
tswiczko
Master Chief Petty Officer
2000 Silverado 4x4,5.3L vortec, automatic trans, electric shift transfercase
I replaced the carrier, ring gear, pinion, carrier bearings and pinion bearings about 17,000 miles ago and now it's making an awful racket.
I pulled the cover and the ring and pinion are intact as well as the spider gears. It makes this noise for a couple miles then stops...:confused: It literally stops making the noise. yes the fluid level is up to where it should be, there are no seal leaks, I pulled the drive shaft and have no play in the yolk, and no up down play in the axle shaft that I can feel.
Tire on
[url]http://www.facebook.com/video/video.php?v=2624886430333
[/URL]http://www.facebook.com/photo.php?v=2624830508935&set=vb.1500424835&type=2&permPage=1
Tire off
I'll be tearing into this over Thanksgiving break next week and I am looking for suggestions as to what this awful sound is that is coming from my truck or if any one out there has had a similar sound and what caused it
Thanks T
rockyrude
Re: Rear axle again
Based on your two videos, I'd have to believe you have a wheel issue. Maybe slightly ovaled lug holes? I'm sure you would feel it though driving it.
Failproof
Re: Rear axle again
Outer axle bearing, or parking brake rubbing inside of hat. That's my evaluation from far away!
Bob_VT
Re: Rear axle again
I would pull the brakes off and inspect the parking brakes............
That clicking is too metallic from being inside the carrier housing and I bet it is in the brakes/parking brake.
Is that a Z-71? Are you sure the auto locker is working??? and releasing?
dolluper
Re: Rear axle again
+3 brakes....throw a nut on snug then run it ....p brake may be loose inside without nut on ...your rotor has a nice groove eh brake noise also..check backing plate
tswiczko
Re: Rear axle again
:facepalm: Boy do I feel stupid. you were right it's the parking brake.
I was currious if it would be that even though I didn't believe it was.
So the next time I drove it I applied the parking brake and lo and behold the noise stopped.
Failproof, and Bobvt you guys saved me a lot of work and head ache and for that I am greatfull.
This has got to be one of the best forums on the www. you can get just about anything answered here.:cool:
thanks for the help everybody
tswiczko
Re: Rear axle again
And Bob yes the govlok is working, I goosed it the other day and it made that clunk that govloks make when they lock up and she got a little sideways on me when the y both broke loose.
Thanks again Bob
