Good Day,
i recently purchased a used 1977 140HP Johnson outboard, the previous owner said he rebuilt the carbs the previous summer have about 50 hrs. i've been having WOT issues(won't go past 3/4 throttle). found a kink in in the lower carb fuel line and i bunch of leaks from old crack hoses. changed them all out. i haven't water tested it yet. while idleing in in my drive way i noticed some drips coming from the rear of the fuel pump. there seems to be a small nylon pin (maybe a pressure release valve). anyway at idle it drips fuel. all my other connections are good primer bulb keeps prime. any thoughts on that damn drip?
don't want to get towed back again this week end.
also on a side note it came with a 15 pitch stainless steel prop. seems kind low to me, what is the designed pitch??
thanks guys
thanks guys
