windshadow
- Sep 24, 2008
- 19
I have a 1995 70 hp when the motor was running on my last time out, she just slowly lost power and shut down,after a few min she started back up and I got her home and changed the thermostat,and water impeller good strong water jet run the motor in the tub for about 15 min no proplems went back on the water ran about 100 yards motor shut down again. took her to a marine shop they checked her out in the tub ran fine they took her to the lake put her in ran about 100 yards motor shut down they then said they did a compression test and one of the cylenders had bad compression, now they want 3600.00 to rebuild the power head,I found a shop that will rebuild the carbs and the power head for 1900.00 if I let them do it should I take the vor pump out and mix my own fuel? thanks for any info. and what will I need to take the vro out of the mix?
