KRH1326
- Sep 22, 2007
- 491
Hi All,
I have rebuilt my 351W, Holley Carb and outdrive.
I followed all instructions that came with any parts or kits, and followed good practices that I could find in my Ford, Holley and OMC manuals. I took my time ( 1-1/2 years ) and tried to do everything "just right".
These are in a fairly heavy 24' 1976 Winner Flybridge Sportfisherman.
Carb is Holley 4 bbl, vac secs, elec choke.
I first ran and tuned the unit in my shop. I built a steel stringer mock up, and had all units together. I even built a steel drum of water for the outdrive to run in, including circulated cold water for the drive to draw from and a fan vented top to vent exhaust outside.
I ran the boat for the first time and developed this problem:
Backfire through carb at or above 3000 rpm.
It started just fine, idles down ok, temp never breaks 140 degrees, beautiful oil pressure. Timing is 10 btc, gap and dwell are right on, right out of the book.
What can cause this?
From my teenage years of old ford pickups, my experience is to suspect bad timing, though my numbers seem just right OR not enough fuel to air running down the beast's throat. I do have a slightly rough idle <700 rpm, but I think that is a different prob ( I may have a minute vacuum issue that I am trying to track down.)
I am starting to chase my own tail with this, and am looking for a fresh view point.
Any suggestions?
Thanks
Any suggestions?
Thanks
