nola mike
- Apr 22, 2009
- 5,695
Re: Rebuilt carb, same problem
yeah, i was thinking that since i don't have symptoms at higher rpms. but my idle is fine, so i guess that probably isn't it. do you still think it has to be the AP circuit? why do i have problems starting with the throttle open if that's the case?
An air leak affects the IDLE speed/mixture more than anything else.
The higher the manifold vacuum (idle/cruise) the more effect the leak will have. A leak is essentially imperceptible at open throttle.
