Recommendations on a good speedometer system.
Bubbasboat
I want to replace my speedometer system, it's pretty cheesy and old as well. I'm not looking for exotic, just an honestly priced, good working and reliable system. Any suggestions?
UncleWillie
Re: Recommendations on a good speedometer system.
It sounds like you are replacing it for cosmetic reasons.
Speedometers are all inherently the same.
Expect the new one to work just as well as the old one, only look different.
How big is the budget?
FYI, other than the light, they are not electrical devices.
Bubbasboat
I wasn't really clear, my fault, Actually, I'm replacing it because it does not work. They are all vacuum aren't they. So fancy is the only real difference? My budget, enough to buy a decent item that works, I'm not so needy of fashionable.
UncleWillie
They are not vacuum.
They work off of the water pressure from the Pitot tube on the transom or built into the lower drive unit.
If you can not develop pressure from the water. You will not get any speed indication.
Blow by mouth, as hard as you can into the pickup hose. Expect to see ~10 mph.
What Speedometer? What Boat? What drive? Details!
Bubbasboat
Sorry, I did know that. I'll try the blow test. Mine is the pitot tube on transom. Also an old system. Thanks
dingbat
In reality, pivot tubes work off air pressure. The water pressure compresses the air inside the tube that generates the force on the gauge. Once water gets inside the tube, performance suffers greatly.
The usual cause of water infiltration into the system is a leaky hose or connection at the gauge. Pull the tubing off at the speedometer and blowing back thru it. If you find water, check for leaks in the tubing...cut a short section off the end of the tubing before installing back on the gauge to make sure you have a good seal at the gauge.
Bubbasboat
I would like to thank everyone for all the absolutely great information about servicing a speedometer system!
I NEED to replace my system, Pitot tube, speedometer, etc. This has not worked since I got the boat. It's no big deal, access is great on my hull and interior!!
Should I spend $10 for all the parts, or should I pay $150? I need it to work reliably,
I don't go that fast anyway, more curiosity how fast I'm really going!! I am putting a 70hp on it, the boat in my profile photo. My current hull. OH, FANCY is of no value, just function!
Any thoughts?
Thanks
dingbat
Any thoughts?
Thanks
I personally would trouble shoot and fix what's wrong. It's nothing but the Pivot tube, some hose and the gauge.
Never known a pivot tube to go bad unless physically damaged. The tubing has the highest probably for damage.
UncleWillie
I personally would trouble shoot and fix what's wrong. It's nothing but the Pivot tube, some hose and the gauge. Never known a pivot tube to go bad unless physically damaged. The tubing has the highest probably for damage...
+1
You could replace the Speedometer and Pitot tube only to find it still does not work because the hose pinched in the middle. Throwing money at a problem is just throwing money away.
If you feel that $20 is not worth the effort to find the problem.
Do this, take $20 out of your wallet right now.
Now burn that $20 just for fun. If you can't bring your self to do that, go find the problem in the boat first.
The Test...
Remove the hose from the pitot tube and blow into the end of it.
The far end of the hose is blocked by the speedometer so no air will actually flow, only pressure.
If you can get air to flow into the hose, it is cut somewhere
A health set of young lungs should be able to blow ~10 mph.
If you get Zero on the gauge, Remove the hose from the back of the gauge. It just pulls off, no connectors.
Blow into the Hose from the gauge end. You should be able to blow air out the open end by the pitot tube.
If not, the tube is Pinched or plugged with mud or insects.
If air comes out the other end, reattach it to the pitot tube and blow again.
If the tube is now blocked, the pitot tube is plugged up with mud or bugs.
Should have asked this first... Is the Pitot tube Mounted Correctly?
Bubbasboat
OK! I went down and did the tests on the system. Did as you outlined, got about 15 on speedometer from stern, I went straight to the Pitot, it was clogged totally. I blew it out, get flow from one direction, inlet direction, but what would be the drain direction the flow is significantly less, but I can blow bubbles through it. Is this normal? By the way, I'll save the $20 anytime!!!!!!!!!!!!!!
+1
The Test...
UncleWillie
Perhaps flushing some water through it or the assistance of a fuzzy pipe cleaner would help.
The tube is open at the pitot end but blocked by the Speedometer, so there is no actual flow needed in the tube, only pressure. If the tube is open at all, it will work. At least until it gets plugged up again.
I am glad you didn't go the "Replace Everything" route because of a dirty pitot.
Bubbasboat
So am I! Thanks
UncleWillie
Here is another "Outside of the Box" Idea.
The next time you take the boat out, pull the tube off the pitot and run around at speed for 5-10 minutes.
The pitot will be flushed out by the "Poor Mans Pressure Washer" action of the water.
You many look like an over sized Ski-Doo from the water fountain. :D
Bubbasboat
That's cute, and it would work and look interesting for sure!
