Re: rectifier and diode ?'s
The rectifier only cares about charging the battery....nothing else. <br /><br />You should have two yellow leads coming from the stator. The yellow leads coming from the rectifier should connect to the stator yellow leads on the terminal strip. One lead may have a gray stripe on it...this is for the tach lead to connect to. The red wire from rectifier goes to the battery for charging. If I recall on your engine, it will go over to the starter solenoid and connect to the same post as the battery cable does.<br /><br />I've cut and pasted an explaination of the shift diode below written by Joe Reeves. It explains why the shift diode is there and saves me from doing the typing....
<br /><br />It's purpose is:<br /><br />The lower unit has a spring loaded shifter clutch dog. With no voltage supplied, the unit is in forward gear.<br /><br />With the key in the on position and the shift switch in neutral, voltage is applied to the lower unit solenoid (green wire) to neutralize the shift.<br /><br />With the engine running and then turning the key to the off position, the charging system comes into effect, supplying voltage to the shift diode which in turn supplys the needed voltage to the lower unit solenoid to keep it neutralized until the engine stops (no rpm).<br /><br />If that diode wasn't there, or if it was faulty, the lower unit would slam into forward gear the instant the key was turned to the off position, momentarily jerking the boat forward (not a good thing to happen). Bottom line... If your pack fails, it's not the diodes fault.
