rectifier hookup
levi_tsk
Ensign
ok so i just bought a new rectifier for my j140tlcim johnson and its got two yellow wires coming out but neither of them have a grey stripe so my question is does it matter which one i hook up and where so long as its yellow to yellow and red to the red?
ONERCBOATER
Re: rectifier hookup
yellow goes to stator.... stator produces alternating current no big deal there. red goes to battery/charging/positive.
Did that answer your question?
Sean
levi_tsk
Ensign
nope
my stator has one solid yellow and one yellow and grey striped wire the rectifier has two solid yellow wires and a solid red ( i know where the red goes) im trying to figure which yellow goes to the yellow grey or if it matters
Fed
FWIW Levi I have a 1988 90HP and one of the stator tests is to make sure there are no ground faults in the stator, this indicates that there is supposed to be no ground within the stator circuit. This in turn means that there is no potential difference between the stator wires & the rest of the electrical system until after the stator has been connected and then the rectifier does the grounding.
Bottom line, it shouldn't make any difference which yellow goes where.
F_R
Simple answer ---it makes no difference.
levi_tsk
Ensign
ok frank thank you!! i just didnt wanna fry my new rectifyer or my stator or worse my boat :D
