rectifier on 1980 merc 115
jimg984
Re: rectifier on 1980 merc 115
+ is red wire
~ is the 2 yellow wires with the brown wire attached to one of the yellow as shown in your wiring diagram
dont matter which yellow the brown is attached
and the yellows are interchangable
dont test to see if charging by removing battery cable
jimg984
by the way if your R S rectifier has a 4th connection it would be for a ground
org. rectifer was self grounding
Chris1956
Normal Bridge rectifiers have 4 terminals. The -DC terminal needs to be grounded tot he motor's block.
markmac
ok thanks guys, 1 more question. does the tach wire go to the + terminal or with the lone yellow wire on the ~ terminal?
