Rectifier Replacement
Crest990
I have a 1977 BlackMax 175HP. The rectifier tests bad and I'm looking for a replacement. I've read a few posts where people talk about a radioshack substitute that works great. I could use some info on this.
Thanks
Crest990
Re: Rectifier Replacement
Thanks ricksrster. Are there any special instructions to follow when making the replacement, or is it a pretty simiple change over? Will I need to modify anthing on the engine? I'll be picking it up after work today, so I'll hopefully have it up and running by the weekend.
ricksrster
Ther was somebody that used one and took pictures that he posted in the forum. I can't remember who is was. It was a while back. I think he used one of the original holes on the motor to mount the new rectifier.
phatmanmike
it was me, but the post is long gone now.
the radio shack rectifier has 4 posts on it. look at the diagram on the packaging, its really simple once you understand it.
2 have " ~ " on them. these go to the yellow wires from the stator, they are your alternating current input.
1 is the positive terminal. this goes to your main hot feed for the 12V+
the last is the ground, this terminal gets attached to a secure ground on the block anywhere.
the two ~ terms are diagonal of each other, as are the + and - terminals. have fun, yes, it really is THAT easy
phatmanmike
it will look SOMETHING like this..... i color coded the terminals, they really aint color like this.
Crest990
Thanks for all the help. It's pretty simple as you said. The pictures were helpful too. The problem seems to be fixed, now if I could only figure out why the key won't kill the engine.... only boggs a little like it's running off of one side. Any suggestions??
Chun-Mu
just one quick questions; hate to jump in in other peoples thread
Does this rectifier also have a lead that can be wired to the Tach? Also this rectifier doesn't seem to have the voltage regulator integrated...
Chundriss
Chris1956
Chundriss, There is no regulator integrated with the rectifier. Did the original have a rectifier?
Either of the stator wires will be the sender for the Tach.
