HT32BSX115
- Dec 8, 2005
- 10,083
Re: reg or prem fuel ?
If you have a LOT of water in your fuel, you should look elsewhere for the source.....the most common sources of water intrusion are the vent, fuel fill opening and the fuel supplier itself! NO amount of snake oil will mitigate that water in the tank. If you have more than a teaspoon or so in any recreational boat fuel tank, it's not from condensation.
Condensation is not a big source of water in any fuel tank.
http://www.yachtsurvey.com/myth_of_condensation_in_fuel_tanks.htm
I would agree with that except for one thing. Ethanol has a nasty tendancy to attract water. Lets set aside that fact that the boat is operated in the water and just consider the amount of time between fill ups and the storage time vs. a regularly used automobile. I waste a lot of fuel by regularly draining my boat tanks to clear them of accumulated water. You would be suprised how much is sitting in the bottom of a tank after a long lay up. I was always under the assumption that Stabil or a similar product would prevent this but I've found that to not always be the case.
I may be a bit over cautious but the way I figure it, it's easier to fund a new tank of gas than a new motor.
