reglueing headliner in cabin ?
canman
hi everyone , the headliner down in the cabin of our boat is starting to sag , is it possible to put a small slit in it and spray some contac cement up into the liner and then wait a few minutes and push it back up and hope it sticks ? i dont know what else to do . thankyou ...
canman
Re: reglueing headliner in cabin ?
thanks , i will give it a try ..
robert graham
If your headliner is similar to an automobile's, then it's laminated to a thin foam rubber and the foam deteriorates and the headliner de-laminates. If it's possible to remove the entire headliner from the boat and re-glue it, it would work a lot better. If you can remove it, you can buy vinyl/foam laminates at a piece goods/fabric store and just replace it. If not, maybe you can try to glue it or tack it back up with some type of clips or mechanical fasteners? Good Luck!:)
