i like the color of that stain , looks rich!
Their are some bubbles. But realized I'll be putting accessories over those areas.
Couple more coats and good to go....the moderators do like to have fun don't they though.
I put 7 coats on IIRC on the WM .. Sanding between each coat .. Probably could have used another 3 but just got tired of sanding .. Did you thin the first coat 50/50 ? I have decided the varnishing is not at all easy to keep stuff out ..
Are you rolling it ? I would roll it then tip it down flat with a good brush ... That helps remove the bubbles from the rolling ..
Been off the site for a bit and just catching up. WOW you've been kicking some butt in spite of everything else you had going.
