Re: Reinstalling drive
With the clamping screws I give the outdrive a little shake, side to side to see if there is any play, then tighten. When I did mine initially it had a lot of play (1/2 inch or so). Retorquing the screws fixed that, and have not had a problem since. To retorque I just back the bolt off a little and retighten. Don't feel bad about not knowing about, I'll bet 90% of the folks do not include it in annual maintenance. I learned the hard way:facepalm:. As for the ring, nope, seemed to go in OK, but I was tired and frustrated when I did it. Since then I have built a outdrive stand to help with the install, and make sure that the ring is glued in solidly.
