This is the link to my restoration thread. http://forums.iboats.com/forum/boat...und-pro-v-1800-dlx-rebuild-rewire-and-remodel
I'm kicking around the idea of putting 3 batteries below the deck in the center. Thoughts? Eventually I'll be upgrading to sealed lead acid or AGM batteries. I'll need to raise the deck up 1 inch for proper clearance. I think I would build a 1" square tubing "frame" that would run along the stringers and be all welded together. Then I'd attached the frame insert in the deck area and screw to the stringers. I would put a door over the battery compartment. I have an on board charger to charge them and I would route an extension cord hookup up by the gunwale. I hate having the batteries back by the motor because of the weight. Then I could repurpose the raised deck in the stern to hold all of my tackle trays.
This would accomplish multiple goals of mine. 1) Move battery weight forward. 2) Build tackle storage in boat. 3)Keep as much open room in the deck as possible.
I'm 75% ready to pull the trigger on doing this. Thoughts? What could I be missing that would make this a bad idea?
