REMOVAL OF CONNECTING ROS FROM CRANK
1989 YAMAHA 40 HP ENDURO, HOW DO YOU REMOVE THE RODS FROM THE CRANK, I AM USED TO EVENRUDES<br />THIS IS TOTALLY DIFFERENT. THANKS FOR ANY REPLIES
Ray Neudecker
Re: REMOVAL OF CONNECTING ROS FROM CRANK
Motorcycle type crank. Crank was pressed together with rods in place. Basically non servicable. Later models were built with the rods bolted on.
rodbolt
hello<br /> those cranks are normally repairable. call ackermann marine in wilmington NC. last one they did for me works well. all new bearings and 2 rods set me back about 400. on a 3 cyl suzuki<br /><br />good luck and keep posting
mrn714
Hey rod, I got good service from thoes guys as well.
