Re: Removal of Fly Wheel 9.5 Evinrude
Thankd,We put our wrench on the nut, then hit it with a hammer and the inerta
allowed the nut to come loose.We removed the fly wheel like you said.
Then we removed the drain plug for the carb and only a little gas came out as we pumped the bulb.
We opened up the carb and it is full of fine trash and rust. We are going to boil out with muratic acid but can't figure out how to remove the flat head screw under the gas throdrale plate. see picture.. We need about another 1/2"to get the screwdrive into the slot.
Is there an easy way to get that flat head screw out so we can remove the carb?
