namstarfire
- Apr 27, 2010
- 6
hi.
i took off the tilt motor and found out that my tilt shaft is broken.
i took off clutch cap and got most part out.
now i'm stuck where the clutch gear (big brass one) don't slide out.
and i took out the c-clip from the back end and try to push the tilt shaft out from the tilt motor area, don't slide out.
anyone knows how to remove that clutch gear?
after clutch gear remove do the tilt shaft with the worm gear just slide out from the back end?
thanks.
thanks.
