elwilliams13
- Jul 4, 2003
- 137
Powerhead was running hot on one side of my 1991 225 evinrude. took off the head on that side and found complete blockage on top water jacket. While I was in there looked at cylinders and they are smooth combustion chambers clean as well. just a little bit of carbon covering the piston top evenly. Should I scrape this off? What is best to clean all that crud out of the water jacket. Also the piston had a little play all around it in the cylinder. Is this normal?
