OK, so I took my boat to a mechanic about 4 months ago to have him look at it and tell e why it was not shifting into reverse, only forward. After adjusting the cable, it would shift to reverse, but not forward. I adjusted the cables following the manual and it did not help. The boat shop I took it to told me that the shift cable needed to be replaced, and it would be about 400.00$. He told me that if I looked under the outdrive I would see the cable is almost cut in half. Well during the removal, I could not see the shift cable very well (from under the shift drive) and what I would see was running through a fat rubber hose, so I am not quite sure what the heck he is talking about.
So i finally got around to removing the outdrive today to get a look at the shift cable and take a peek at how the rest of the inside looks. Here are my questions.
#1- In the main bellow, there is free standing water in there. You can see a load of grease that is built up around a smaller hole. Is there supposed to be a load of grease in there like that, and is some water in the bellow ok?
#2- there is a smaller hole on the left side of the bigger bellow. When I removed the outdrive, it as loaded with what looks like a white grease / lube. I took a screw driver and cleaned it out, but you can see in the pic what I am talking about. What would cause the white buildup in the smaller hole, and what would cause the water in the large bellow?
From looking at the bellow, I do not see any holes and light from a flash light making it though, so where would the water come from?
