Removing snap clips from aluminum windshield frames
appleo
Old cockpit cover snapped to window frame . Special male snap studs clip into the frame
How to get them off?
Code:
[ATTACH]190060._xfImport[/ATTACH]
jbcurt00
Re: Removing snap clips from aluminum windshield frames
I think they snap on & off, sort of like a C clip...
Yacht Dr.
Those slide snaps ? You could remove some of the frame and slide them out..or you can tape next to them ( trying not to damage the frame) and pry them out with a screwdriver. I personally use a dremel with a wafer cut off wheel to cut the clip a bit before I do the pry out :).
YD.
