Removing speedometer gauge
zul
Dashboard is cracking so I am adding strength wherever I can. Now, I will need to remove the gauges completely. The photo is the back side of the speedometer.
This last wire and nut will not come off. I haven't forced it yet, I don't want to break it. Is this as simple as put a wrench in there and turn it loose? Or is it a different type of fitting?? Can it be removed?
It is from a 1994 Sea Ray 180
Thanks.
froggy1150
Master Chief Petty Officer
Get in there with a xacto knife and cut a small slit the length if the brass barb and it should come right off. Then cut that piece off. You want a fresh joint when you put together or it could leak
that is a tube (speedometer pitot tube)
its $20 for a 100' roll
gently pry up with small screw driver
AShipShow
Or while your at it, replace with a GPS speedo, they are much more accurate.
52FordF2
And if you forget to put it back on, the tube may wet your pants :D
