My old Evinrude 5.5hp Fisherman has a leaky lower unit (water gets in) and I have tried to reseal it without success, so I have given up for now and instead I drain the L.U. and refill it each time I use the motor. Is there any simple way to filter the water out of the water/oil emulsion so that the oil can be reused? I have thought about heating the stuff and letting the water boil out, leaving the oil, but I'm afraid this would result in spattering hot oil all over the place. I tried straining it thru a rag which didn't work. I only run in fresh water, and the gears in the L.U. are in great shape and sometime in the future I may get the job done at a local shop, but until then, gearlube is cheap and I drain it out each time - just wondering if there was a way to get the water out so I could use it again.
