Repairing stringer
rickryder
Re: Repairing stringer
Everything looks great nemo! You did a great job with the glass work! You have come a long way! I see a splash in the near future :)
nemo2011
Thanks Rick still a couple of weeks away,sockeye season should be in full swing:D
nemo2011
first coat of bilge paint applied!
View of bilge area from transom,spot at front is for mounting inside transducer!
Motor with new elbows and manifolds installed,Pretty much ready to install back in boat!
nemo2011
Gimbel housing ,inside transom plate exhaust pipe cleaned up awaiting final coat of bilge paint.:)
Woodonglass
This has got to be one of the WORST RESTORATIONS on iBoats!!!!! I tell you what, I'll come haul it off for you so you won't be embarrassed.
Ok, if you're not buyin that, guess I'll have to fess up and say, GREAT JOB NEMO!!!! You DONE GOOD!!!
nemo2011
Thanks Wood,:D Its been a long haul,Not as long as some I know but for me it was long but fun:)
Just that that tremclad I'm using in the bilge area takes a long time to set up:mad:
nemo2011
Well got it running but still needs some fine tuning
moreheadnc
Great thread Nemo! You've done a great job with asking all my questions and taking pictures and gave me a better idea of what to expect when I undertake my project this Winter.
Couple questions:
Regarding build-up
You said you went with PB, then 3" 1.5 oz csm tab, then 6" 1708, then 9" 1708
I am confused by the terminology. Are you saying that you went 3" vertical and 3" horizontal? And by tab it looked like pieces only a few inches wide by a few inches long, like pieces 4" x 6"? Then the 6" of 1708 goes 6" in both directions using 12" wide strips, then 9" in both directions using 18" wide strips, followed by another piece of 1708 that covers the entire assembly from hull over the stringer and down the next side back to the hull? Is this correct or am I way off? Am I adding one too many layers.
My boat is an outboard so I will not have the motor-mount issues (thank goodness).
nemo2011
Couple questions:
Regarding build-up
Thanks Moreheadnc, I did use 3" csm tabbing,then 6"1708 biax on that 9" 1708 biax I used manageable lengths on all, the longest 50"+-'the shortest about a foot where space was limited.
I did not totally enclose the stringers as what was there from the factory was only half way up the stringer and that lasted 22+ years.And mine went up 3/4 of the way. I know some say enclose the whole stringer but IMHO that is a personal choice!as you have to consider weight added etc.
Good luck on your project (It will be fun):D
JB
Westport, PLEASE read and respect our rules. Your post violates rule #12.
DO NOT post to a thread that had been idle for 90 days or more.
