1992 Mercury 25 HP Long Shaft Tiller<br />Model: 1025312MD<br />Serial #: 0D140776<br /><br />Are there any known problems with this type of engine with "Stator" failures ????<br /><br />I purchased the engine in late 2003. The first time out with it, the "Stator" failed. The dealership replaced it free of charge, and the engine worked fine for the next few trips, but then had another "Stator" failure. Once again the dealership replaced the failed "Stator" free of charge, and the engine did work the next (and last) time I took it out in the 2003 season.<br /><br />I took the boat out for the first time in the 2004 season a few weeks ago, and the "Stator" failed again. The dealership has once again replaced the "Stator" free of charge, and the engine is running again.<br /><br />I cannot believe that I have had the unfortunate luck of having a "Stator" fail this many times. It is my opinion that there must be a "Root Cause" for the "Stator" failures other than the "Stator" itself. The dealership just keeps telling me it is a "Stator" failure, and there is nothing else wrong with the engine.<br /><br />Can you PLEASE shed some light on this situation for me, and/or suggest what on this engine might contribute to my constant "Stator" failures.<br /><br />Thank you in advance for your response.<br /><br />Russ.
