Replace a 5hp motor with a 7.5hp motor
gmarshall43
Can I replace a 1958 5hp johnson motor with a 1954 7.5hp evinrude motor? And would it work?
Thanks,
Gary
dazk14
Ensign
Re: Replace a 5hp motor with a 7.5hp motor
Thanks,
Gary
Sure, why not. If the boats rated for it...
Or, could you be asking, can I mount a 7.5 powerhead on a 5hp mid?
oldboat1
as above, not sure what you are asking -- but think you probably want to switch powerheads. First thing to check would be the bolt pattern for each (got to believe you could not interchange). What's the condition of each of the motors? Maybe could get one or both up and running on their own. Maybe lower unit work on, say, the 7 1/2. Does the five have a blown powerhead, maybe? guessing here.
boobie
Need more info ??????
nwcove
even if it will bolt up, the 7.5 powerhead will not fit under the 5.5 cowl.
HighTrim
Wont work at all, under any circumstances. Send to me for proper disposal. :)
gmarshall43
Yes, the idea was to mount the 7.5hp on the 5hp unit. I haven't checked out the bolt pattern but I wasn't sure if the 5hp lower unit would support the 7.5hp motor. I also didn't take into consideration that the cowl would not fit with the 7.5hp motor under it. I know these older motors had interchangeable parts but wasn't sure if I could switch power heads seeing that its only adding 2.5 more hp. The 5hp motor is no good but the lower unit still works and the 7.5hp motor is being sold by its self and was told it is a good working motor. Thanks for the repsonses.
Gary
Chinewalker
The 7.5 powerhead will bolt up, but won't work. '55 & prior used a slightly different water pathway compared to '56 & later. This holds for the 5.5 powerheads, too. You would need a 5.5 powerhead from '56 to '58 to get your motor going again.
Plus there's the cowling issue as mentioned previously.
oldboat1
already have these motors, or thinking of buying them? If buying, can buy the 5 1/2 as a parts motor -- might come up with a powerhead for it at a later date. Could buy the 7 1/2 as a potential runner. Changes issues if you are shopping. You will want to get them cheap, and check them out as best you can before buying -- compression on the 7 1/2, maybe on the 5 1/2 if there is any life. Spark check maybe, but can fix ignition. See if you can get some history. Did I mention buy cheap? Both are parts motors at the moment.
