Replace cone clutch 1999 Bravo III
BillWilliams
I have read enough to know the 1999 cone clutches are not available because MerCruiser upgraded them which requires a whole new gear set as well.
I'm just getting into the investigation point of doing this. Is there by chance a decent list of parts and tools needed to accomplish this?
The serial number on my outdrive is 0L440964.
Thanks
The factory drive manual lists the tools needed
BillWilliams
Thanks. I just found the 2001-17 bulletin that apparently tells me the parts as well.
Is there a way to tell the gear ratio of the outdrive without opening it up?
Turn input shaft 10 times and count output shaft turns
Or look at the decal. It's usually printed on the bottom of the decal
tank1949
BillWilliams
Don't know. I also don't know anything about the quality of the SEI drives so I think I would rather fix what I have. I have a mechanic friend who is checking to see if he has the MerCruiser tools so I can do it myself.
