replaced rectifier and it still is not charging.
Vic.S
Re: replaced rectifier and it still is not charging.
I think we would all like to know why it was not charging..
What was the cause of the problem?
You replaced the rectifier a couple of times without curing it so we assume a defective rectifier was not the original cause.
Pokertrampp
What happen to the rest of the posts? they keep disappearing... I am missing at least 10 or 12 posts from this thread (and others). the last post I am showing is 212, and I know there was 220 a little while ago.
Pokertrampp
apparently the harness was creating some type of short, I found a spot that was missing all the insulation on the entire bundle of wires and they were all bare and touching each other. I replaced the harness and installed a new rectifier and it is charging fine for the moment.
I am not sure why the rectifier would not work on my motor but it did on another motor, but like I said it seems to be working fine now, the tach is even working now.
Good stuff here, I probably dont know anything, but I read somwhere (i.e maybe just on older models) that an outboard will not effectively charge until a minimum rpm is met, which is usually at a higher number -close to WOT..........
Please see my post for Johnson 50 hp bogging down.........thanks
Pokertrampp
That contradicts what was said in an earlier post.
The charging system does NOT kick in at a magic rpm above idle. It will charge at idle; it will charge at WOT. But if the battery does not need a charge, it will not charge. This is unusual, the battery will almost always need a charge. The reg/rect determines whether or not to charge based on the battery voltage, and how much current the battery is absorbing when running. You may see a slight rise in the charging voltage with higher RPMs, but that is what the reg/rect does...it regulates or squelches that higher voltage down to the normal 13-15 volts needed for charging. It is not that critical....we are talking about a boat motor...not some medical device that measures millivolts heartbeat....
bktheking
They charge as soon as they are started up, not as much as at higher throttle.
