Replaced water Pump
AATA
I replaced the water pump on my 200HP Johnson over the weekend and wanted to thank all the people that post info because I read a lot on this site and it went great. The shift rod is definently the hardest part, but it only took 5 or 6 tries and it went in. I lubed the water tube seal, exaust seal and impeller housing with some silicone lube/sealant (non-hardening) that I had around from assembling pool pumps. After the shift rod was lines up, everything went right together.
A couple questions I have after completing the project?
1. The exhaust gasket looked great going in, but how can I tell if it went in straight? You can't see it past a certain point, but I assumed it went in right?
2. I had is how can you tell if the old one was bad, so I know how long I can go without replacing it? I was told when I bought the boat that the pump was replaced 1 1/2 seasons ago and I ran another 1 1/2 seasons. The pump looked find, rubber was soft, not worn, etc. I'm glad I did for the peace of mind, but want to know when I need to replace it again.
I also bought some new trailer lights from Iboats and replaced all the lights on the trailer. Great complete kit!
Thank you!
izoomie
Re: Replaced water Pump
This is certainly the place to be to learn how to do that kind of repair work...
tx1961whaler
Thank you!
1. Have faith.
2. Opinions vary. I don't run mine many hours in a season, in fresh clear water (no sand), and change impellers every 3 years. With a big 200 like you have, I'd probably go to every 2 years since the cooling requirements are more critical and the downside to overheating is more severe.
kenmyfam
Also the rubber ages and you just never know when it is going to let loose. There is never a "good" time for that to happen !!
