Re: Replacing floor on Aluminum boat, suggestions on wood...
Looks great Kewlbird. Did you use resin without laying down any cloth?
With all the reading I've done on this board over the last few months, I'm confused on something. (yea, there's a shocker
) If not using cloth, wouldn't epoxy would be the way to go? I thought fiberglass resin wasn't preferred when using as a direct coating if cloth wasn't being used.
Can someone set me straight? I'm viewing from the same prospective use. Wood in an aluminum boat for decking/floor. Covering the wood with resin (fiberglass or epoxy??) which is then covered with carpet, vinyl, nonskid paint, etc.
