Re: replacing impeller on 1991 Suziki 40HP 2 stroke
Put the motor in gear, losen the cluth rod connector, loosen the lower unit bolts (with care and lotsa WD40) drop the lower unit ... replace impellar .....
best I remember shift into reverse makes it easier, DO NOT pull the shift shaft up far enough to disengage the clutch.
from there its a matter of removing the bolts and dropping the case then removing the pump housing.
