replacing impeller on 1991 Suziki 40HP 2 stroke
blackdogpile
Does anyone know the procedure for replacing the impeller on a 1991 Suzuki 2 stroke? DT 40 04003 133026
blackdogpile
Re: replacing impeller on 1991 Suziki 40HP 2 stroke
Hey Rodbolt Are you willing to divulge that info?
deejaycee_2000
Put the motor in gear, losen the cluth rod connector, loosen the lower unit bolts (with care and lotsa WD40) drop the lower unit ... replace impellar .....
rodbolt
best I remember shift into reverse makes it easier, DO NOT pull the shift shaft up far enough to disengage the clutch.
from there its a matter of removing the bolts and dropping the case then removing the pump housing.
