replacing water pump in '51 Johnson
Status
Not open for further replies.
gmarshall43
I need to replace the water pump in a 1951 Johnson, 5.5hp model TN-27. I have dropped the lower unit but the pump is up in the exhaust housing. How do I get it out?
Thanks
1946Zephyr
Re: replacing water pump in '51 Johnson
Thanks
5.5 didn't come out till 54. You have a 5hp. Those are a star impeller on top of the lower gearcase in the plate above where the gearcase mounts
you'll see some screws on the bottom that secure the housing. Impellers are still available at vintageoutboard.com :cool:
wbeaton
There is also a cable that runs from the neutral clutch on top of the motor down to the lower unit. If its not frayed then remove it from the clutch lever. If it is frayed then just loosen it as much as you can. The following link can show you what to do.
http://hoodad.fortunecity.com/index2.html
PS. Be careful with the lower unit while you are taking it off. Even if you drain the darn thing it'll still try to dump oil all over the place.
gmarshall43
Thanks for the replies. That web site is really helpful. Is the water pump in that '51 5hp the same as the ones used in mid to late 50's 5hp motors?
F_R
The impeller in the TN series 5hp motors with neutral clutch (like yours) is the same as the one for the CD 5.5hp motors with gearshift.....EXCEPT the center hole is too small by .010". If you ream it out .010" (to 7/16") it will work
Purvis
I would also like to replace my impeller on my Johnson TN27 1951 5 HP. The link above at hooded does not seem to work.
Does anyone know where I can find a video on this procedure?
GA_Boater
Start a new thread. After almost ten years any links will be dead.
Closed.
Status
