Resealing Alpha Upper
Fishermark
Hello fellow gear heads! Long time since I have posted on here. I am currently helping my son-in-law with his boat. He has an Alpha outdrive that is leaking out of the upper drive area. I will be replacing the seals. I cleaned up the yoke, and it appears to have a groove that is a bit too deep. I plan on using a speedi-sleeve, but have a question. After measuring the yoke, it is 2.240" in diameter. Doing some research here on the forum it seems like the SKF (and other brands) part number that works is SKF99225.
That particular sleeve says it is .781 wide, while the yoke is only .5" wide. Is this going to cause a problem? Can it stick further in, or will I need to cut it off somehow. Those who have done this before, let me know what you have done. Thanks!
Fishermark
Just to follow up - in doing a little more research, I see part #99227 has the same diameter, but is only .43 wide in total, but only .31 inches "shaft length." For that one, I don't know if it will be wide enough....
Scott06
that should be plenty wide just has to cover where the seal rides. How much is the sleeve vs a new yoke?
If you dont have it get a factory manual for your drive has step by step how to do all repairs and any special tools needed. Usually can find the tools used on ebay for half price.
kenny nunez
Look closely at the lower seal surface of the driven gear. That is a problem area also. A speedy sleeve works good on that surface. Also the lower seal surface below the water pump. When I had my shop I always had a good stock of those sleeves.
To pressure test the upper housing get a small piece of rubber from a inner tube or similar, a piece of 1/4” X 5” X 2” steel 2 pair of vise grips to hold the steel and rubber over the oil transfer port.
Fishermark
Thanks - yes the lower driven gear area looks brand new. I will be replacing both lower seals as well. They came in the reseal kit. But they actually appear to be in good shape.
Fishermark
... How much is the sleeve vs a new yoke?
A pretty big difference. You can buy an aftermarket yoke for around $80 or so. The speedi-sleeve was only $30.
And yes - the shorter sleeve will be wide enough. It is part # 99227 for anyone looking at this in future.
Scott06
Had to take some time off of this project, but now am back at it. I was prepared to check the rolling torque on this reseal, but I think I have an older Alpha that is simply torqued down. Is there a way to know for sure. Check out the video.
Question - rolling torque, or simply torque the nut down.
off your drive serial number and look in the manual it usually says XXXX serial and up use this method or similar
some detail on it and shows the two designs that are visually different.
not sure if I have the serial number cutoffs in my manual or not will look tonight
