Re: Resistor for nav lights
This is a simple diode, not a resistor. Radio Shack can fix you up for just a few cents. Even though you have two switches, they function as a single center OFF, up NAV, down ANCHOR switch that has three terminals. To make a long story short, you can't make a switch like that turn on the stern light only, or both the stern and bow lights at the same time. The diode prevents current from going to the bow light when the anchor position is selected. Simply connect the new diode between the terminals that feed the bow and stern lights. A diode allows current flow in one direction but not the other so proper orientation is required.
