restoration complete...now handling problem
dave1989
I just completed my project of a stringer/deck replacement and repower from a 4.3 to 5.7 on a 20' bowrider. I couldn't have done it without you guys! The problem I am having is it now wants to plow the bow at speed. The faster I go the harder it pushes down. The 3 things I can think of would be a hook in the hull, The stern of the boat being lower from extra weight, thus lowering the outdrive, or the my new prop. It seems like the extra weight and lower stern should make the bow ride higher? I checked the hull last night and in has no hook at the keel and gets progressively more as you get towards the sides. The outside chines have a hook of about 3/16" but look as though the were built this way. Do you guys have any Ideas?
erikgreen
Re: restoration complete...now handling problem
Hmmm... a "hook" is a depression or hollow in a hull surface. If you mean there's no hollows in the flat or curved parts of the hull, that's good. The chines should have no hollows at all unless there are ventilation gaps, probably not on your boat. I'm guessing you're referring to the fact they angle opposite the curve of the hull inward rather than a hook?
If your bow is digging in, first check your center of gravity. Do this while the boat is stationary... ideally the painted lines on the hull should show you where the load is. You can also check it on the trailer. I'm guessing if anything you're heavier in the stern which won't dig your bow in directly, but check it anyway to make sure it's not your fuel load or some extra fiberglass added that is putting weight where you don't want it.
I'm assuming you don't have trim tabs. If you have a whale tail on the lower unit, take it off.
Check that your cavitation plate on the lower unit is roughly at the height of the bottom of your keel, and that it's level front to back. It sounds almost like it could be tilted too far in, thus shoving the bow down. This may have been the case with the older motor too, but it might not have been a problem, so even if you didn't alter the transom or gimbal, check it anyway.
What happens if, when running and the bow digs in, you trim the motor out to raise the bow? Nothing? If so that's either a lot of weight forward or a hook.
Post some pics of the bottom of your hull so we can see what's going on there. Try to show some low angle shots of the hull bottom and lowered sterndrive in position.
Erik
Chris1956
A lot of boats have a built in "hook", usually at the extreme rear of the hull. this helps them get on plane. Since a lot of boats come with power options, and your retrofit is not outrageous, I wouldn't think this is your problem.
You don't have anything that is dragging in the water? No misadjusted trim tabs or whale tails? if you trim the motor, will it get better?
dave1989
Thanks for the quick replies! No extra weight in the bow only life jackets and bumpers. (same as before) The belly gas tank is the same and the same location between the helm seats and the engine compartment. I do not have any whale tale or trim tabs. The stern seems to ride about 4" lower at rest in the water than before. I trimmed the motor to the point of cavitaiton and it did nothing for the bow lift. I will take some pictures of the hull this evening, and check the cavitation plate height. Thanks again guys.
dave1989
I took some pics and did some measuring last night. I didn't have a chance to put the outdrive back on but I measured from the bottom mounting stud to the cavitation plate and the plate was about a 1/2" higher than the keel. I took a few pictures of the hull
this is the chine I was talking about
and this is the 3/16" hook about 2' from stern
Sure seems like this hook could cause my problems??
